Whats the best pump for a small turbo. Car is only standard, but i've read that the pumps are marginal even on standard cars?
You don't want the standard pump on Stage 1 or above as my mate found out to his cost, he melted a spark plug & an exhaust valve on his Stage 3 setup, he also manged to weld part of one of those items to the top of the piston for good measure.
I'm going for a Walbo pump in my ST but I'm only aiming for 350BHP.
Mines standard and staying that way (even though Mike R thinks its ) so will the standard pump be ok?
Only way to be
It must be good enough as they wouldn't have used them otherwise, mine is on a standard pump and runs perfectly and was spot on fuelling wise on the rolling road day last year
near enough matey, just a stainless with motorsport cat and K&N was running well at 254bhp last time and that was with a little niggle with the wastegate, which should have been sorted now
Sounds the same as spec as mine, mines done 240ish a few times.
