Originally posted by cossiecrazy
View Post
removal of front struts advise anyone please?
Originally posted by FrancoI saw that....
If you cannot get the top 19mm nut off (above the turret) put an allen key into the top of the shock shaft and undo.
Ps what do you know, fixed your dash lights yet
Originally posted by adam ant View Posthi mark i have konis on my motor and when i try and undo the 19mm top nut it turns so i tried to hold the 8mm nut while trying to undo 19mm and the whole metal cup has come seperate from the rubber round washer thing is this normal cos the opposite side came undone ok and just the thread is going through hole ok
steve
NSSCC 2016 Class B1 Champion
I think you can fit a 8mm socket over the top of the shock.
If I remember rightly I used a 19mm Ring Spanner and a 8mm socket to stop it spinning.Paul Hales
adam ant try using an 8mm spanner on the "flats" on the piston rod. As long as the piston rod does not rotate then the 19mm bolt will come undone if you have enough force on it.
It doesnt matter if the strut top plate rotates. Theres nothing to stop it rotating anyway as all it does is stop the damper falling out of position when theres no load on the dampers.
Originally posted by Craig H View PostI have to paint mine whats the best paint to use on them?I used hammerite and it runnedthen tryed plastic cote(i think that what it is)and than runned aswell
just put strut brace back on but when i did the drivers side strut before putting wheel back on i turned the hub clockwise and anti clockwise and i am getting a clicking noise and also the drive shaft box moves when it starts to get tight before it clicks?what is this and have i broke something or is this common also when wheel is back on it also clicks when i go to tighten up wheel nuts help please any one
Originally posted by adam ant View Postjust put strut brace back on but when i did the drivers side strut before putting wheel back on i turned the hub clockwise and anti clockwise and i am getting a clicking noise and also the drive shaft box moves when it starts to get tight before it clicks?what is this and have i broke something or is this common also when wheel is back on it also clicks when i go to tighten up wheel nuts help please any one
Originally posted by warrenpenalver View Postslight clicking on doing up wheelnuts is ok.
Im not sure what you mean with other clicking?? is it slight movement of strut as you do bolt up?? or is it CV joint noise??? You havent pulled the shaft out have you?? dont know how easy that is to do!
