Air injector info ......
  • Air injector info ......
    Are they worth it ?
    Which are the ones to get?
    How much should i be paying?
    cheers.
    Low Slung Denim.
    Pros
    Give accurate boost control
    With Pectel board and controller, can give 12 position boost control on the Webber ECUs
    Cons
    Fail UNsafe, so needs to be set up so that if they have an issue, max boost is only that what the car should see on highest setting (can be tricky with a big turboo), otherwise you will get unlimited boost...
    Expensive (£350 new for the twin ones).
      will be used with a t4 ??
      Do you sell these mike?
      Low Slung Denim.
        you should be using 842's which i supply (injectors only) gas type.
        BOSCH PARTS 07759984033
        INJECTOR CLEANING
          ...however the best boost control out there bar none is the JG rallycross type manual adjustment via knob which can be incar or underbonnet with the twin feed actuator....will not spike though you dial in 2.2bar that what you get not fluctuations.
          INJECTOR CLEANING
            How much
              To you £52+vat each
              INJECTOR CLEANING
                To you £52+vat each
                Will call you (not text ) next week, need to speak to Martin first.
                  Hello stranger where have you been hiding?
                    In the store room, with your ex boss!
                      rather you than me mate
                        but i'd still need the end cap parts aswell tho right?
                        Low Slung Denim.
                          Correct, and the loom and the correct size bleed off hole etc.
                            can you supply any of the above mike?
                            Low Slung Denim.
                              Guess where to look .
