oil cooler, big wing sump,oil brather, alloy rad, alloy turbo cooler, alloy swirl pot would this make the engine run to cold could it cause it to blow?
is this a dangerous engine spec...
You can't say until you see what temps it runs at with this. However, my advice would be to do it in stages, and ONLY add extra cooling once you find out IF you need it. The oil needs to see 110°C to enable the impurities to be burned off and the water being at 100°C to 110°C is NOTHING to be worried about on track, as it doesn't boil until in excess of 120° with a pressurised cooling system like the Cosworth runs (even higher if you have an uprated tank and cap).Mike Rainbird
Depends on the power and the use it is put to and for how long. I did a 20min track session in my 500bhp Sapphire in 30°C ambients and the hottest I ever saw was 132°C oil (normally was no more than 120-125 tops or 115 in more normal English weather). I thought this was acceptible. You would have to test and see for your car
hmm
my oil barely sees 100 degrees, so this is too cold?
oil cooler 13 row, mocal oil water temp part and the standard oil water thing.
using 10W 60 oilwww.turbostylez.de --> german Cosworth Forum
