oil pressure sensor
  • oil pressure sensor
    are these still available for oil pressure sender and gauge sender?
    yes. its a vdo sensor.
      almost sure its this one...
      http://www.etbinstruments.com/index....product_id=146
        Originally posted by twin turbo View Post
        I bought mine from the same place about 2 months ago, think it was about £40 with delivery, works perfect
          Can I resurrect this thread rather that start another?
          I've got a oil pressure gauge in the banana pod doing nothing, no movement at all.
          I've found the two leads that go onto this VDO pressure switch/sensor and I've taken them off the sensor for some testing.
          If I earth out one side the red oil pressure light on the dash comes on but if I earth out the other the pod doesn't do anything but should it, would earthing that move the needle normally?
          Then, when I come to put them back on, is there anyway of knowing which should go to what terminal as I understand from this link that one is a switch and one is the pressure so a variable resistance.
          Thanks as usual
          Justin
            Connection details from VDO
            John
              The needle should go to max if the gauge wire is earthed.
              John
                Thanks for diagram John, I did run through their site but didn't see anything so emailed them but this will save me waiting for a reply, brilliant.
                And thanks for confirming what I suspected that it should go full scale on being earthed, so I have a break somewhere which I'll try and track down tomorrow
                I guess all the gauges in the banana pod share the same +12v supply, well the battery voltage anyway as boost is mechanical - problem is I can't see the wiring diagram for them in my books anywhere to double check this presumption.
                I can see though a Brown/Red (gauge) and a Brown/Green (dash light) that are in the diagram heading to the VDO unit so I have something to hunt for.
                All good fun.
                  Minor gauge clustor.
                  Fuse numbers could be different.
                  Description Fuse Amps Wire
                  Voltmeter 12v power 2 3 Rd
                  O.P.G. 12v power 27 15 Bk/Ye
                  O.P.G. sender Bn/Rd
                  Voltmeter ground 0.75mm Bn
                  O.P.G. ground 0.5mm Bn
                  Electroluminescent light Bu/Gn, Bu/Rd
                  John
                    John, that's great, fuse 27 fine both sides, took pod out, good 12v on Black/Yellow but grounding Brown/Red did nothing.
                    Took unit apart and windings look like a 60's hairstyle so I think we have the answer to no oil pressure gauge. How on earth this happened I have no idea!
