Hydraulic clutch
  • Hydraulic clutch
    My car is fitted with one of the first hydraulic clutch kits that Reyland did using the willwood master cylinder
    It's eventually given up and leaks so needs replacing
    What others are people using and will the mounting holes be the same as don't want to be drilling and I presume they all fit the pedal box the same
    just get a New wilwood? its probaly a "girling" type? size should stand on the housing on the cylinder
      maybe a phone call to Martin to see if he knows or he may have a Willwood in stock.
        Were some people using BMW master cylinder? Maybe worth a search back through some threads.
          http://www.escortrscosworth.com/foru...ighlight=slave
            Geogie that's the slave cylinder I am after the master which bolts on the bulk head
            Martin no longer uses the willwood ones for the reason of them failing he changed to another type ages ago
            I was hoping either mark barber or cossiedave would see this as they both make their own kits up
            I would prefer one with a remote reservoir as the willwood one has the reservoir ontop and sometimes can get a little hot
              landrover 0.75 graham i may have one to compare buddy
                I am back from Tenerife on Saturday mark so I will get the old one off and give you a call to compare
                  I use landrover master as tidier with built in pot so out the way and no ugly looking pot under bonnet fitted loads and work perfect
                  Mapped by MAD 732.4 bhp 570 lbs torque
                  Swindon RSOC Chairman/RS Combe organiser
                    got any links
                      I make the kits up myself
                        Mark do you always have these available as want the hydro setup put on my car when you guys have the car
                          Yes i can get cylinders following day and make up pipe so no probs
                            Nice one!
