Saggy Front
  • Saggy Front
    I'm hoping to look at an Escos in the next week or so. The owner has provided an honest looking ad acknowledging the vehicles faults including a saggy front end (see link to the ad including photos on this site).
    http://s1172.photobucket.com/user/hsc911/media/Escos/IMG_0922_zpsb35d25f0.jpg.html[/IMG]
    http://s1172.photobucket.com/user/hsc911/media/Escos/IMG_0923_zpsa0bacf53.jpg.html[/IMG]
    http://s1172.photobucket.com/user/hsc911/media/Escos/IMG_0924_zps41e366f1.jpg.html[/IMG]
    Do an members know what may have caused this, have any experience of repairing it and if so an estimation of cost?
    COH555
    link doesnt work ? use the bottom code on photobucket
      What's sagging? I can't make it out. If it's something like the bumper hanging low then that's an easy fix. The bumpers height can be adjusted while still on the car. If it's the stone deflector that's sagging then.. all OE ones do. Well, most of them do.
      I can't think what else could sag? I know Sapphires can suffer from saggy bumper syndrome where it looks like the gap on the bumper is rippled, but can't say I've seen or heard of an Escort suffering from it.
      Either way, none are anything to walk away from buying the car. Or particularly worry too much about.
      $5?.. anyting you want
        Saggy Front
        I presume he means a rippling front splitter in which case a simple carbon upgrade will do the trick
          Apologies. Hopefully the images have copied below.
          You should be able to see that the front bumper is hanging about an inch lower than it should.
          COH555
            looks like someone tried to take the bumper off by undoing the adjuster...hard to tell without checking tho
              thats how myn went back on when i removed it via the adjusters, also my wing brackets are damaged
                Easy enough job to sort and shouldn't take no longer than 30mins to put right
                  Fort number plate looks very low as well
                    Very straight forward fix. Easier with 2 people, but I sorted mine using a jack to push the bumper up while I tightened the retaining bolts.
