brake lines
  • brake lines
    i cann't find a pic how brake lines are routed on the front end.
    I have solid lines that end under the crossmember, as i am looking it seems that one flexibile one goes from solid line to the damper and another from damper to the caliper, a pic would be great.
    This any good?
      There's a solid pipe that connects under each chassis rail between solid running to pump and flexi at caliper. There's a bracket attached to the chassis rail using crossmember bolt. This it what the flexi and solid brake pipe join at. Mine are missing, so haven't got a pic, but bought these brackets and short brake pipe lines to fit as mine have no support under each chassis rail......not good!
      Paul, I think he wants a pic of the brake line at the bracket under the chassis rail.
      Scouse.
        Only picture I can find. You can see it in the back ground with the green pipe going to it.
          2nd pic is great mate.
          so, does a flexi line from that joint that is holding to the bracket goes directly to the caliper (which makes no sense as it would be too long) or are there two of them, one from solid line joint to the damper and other from the damper to the caliper?
          Scouse where did you get the brackets from?
            The end of the flexi goes through the bracket and then you get a nut that goes on the other side of the bracket. Then the hard pipe goes on the end of the flexi.
