Does anyone know what can be causing this. Went out to car this morning, started it and the temp guage just shot right up past the red line. Used the car las night and it was fine.
Temp guage going into the red as soon as I start it up!!!
Originally posted by mboon View Posto right, its snowing here again lol.
you got coolent? have you recently changed the rad etc? not burst a hose? split or leaking? thermostate might be up the duff, does the fans kick in straight away?
Originally posted by s7evo View PostCoolant is ok, not changed the rad and there are no leaks, had it up on a ramp last night, when my mate was changing the brakes and i had a look then, no the fan doesnt kick in straight away. Where can I find those wires Franco?
I took mine off, cut It and added a bullet connector big enough to slide over the temp pin.sigpic
There will be a break in the wire and it is going open circuit and off the scale?Mike Rainbird
I started to reply, got called out to the workshop and then when I did, you had already posted .Mike Rainbird
