removing old engine loom and fitting redline tuning new one. need to connect 5 wires into ecu plug. wires are grey/white, brown/green, brown/yellow, red, grey. anyone know which is for what, think should be rev counter- ign supply - fuel pump - temp gauge and another. also 3 black wire from ford immob go into ecu pin 4 cps, pin 10 efi relay, pin 28 fuel pump relay. any ways of bypassing it or just spline into same on new loom. cheers guys big turbo escort cosworth
new engine harness wiring
i did phone them they could only tell me the sierra colours which are completely different. its a wipac immob sure i seen posts on here before about removing. any help would be great
sierra colour is
rev counter - normally green
ignition supply - normally black
fuel pump- normally black/red
temp gauge - brown/ white
one other red/blue doesnt say what for
escos colours i have which i dont want to tie into until sure are
grey/white, brown/green, brown/yellow, red, grey. these come out ecu and are the only 5 that go into the bulkhead wiring the rest all go to sensors etc in engine bayLast edited by kkenzie1979; 17-10-2013, 10:14:20.
easy to figure out, you need a wiring diagram for a cosworth loom off google images if you don't have any on your computer already.
The a multimeter to check where the wires lead to.
For example the fuel pump relay will have a feed out to the plug.
The ignition amp will lead to the plug for a rev counter
Ignition live will lead to the relay
water temp to a small connector on the loom and plug
etc etc.
