Water injection , how to control it ?
  • Water injection , how to control it ?
    Hi all ,
    I've had a water injection kit in loft for a while and going to fit it over Xmas .
    How do I control it ?
    On l6 ecu , I have a act gauge from mike , I've heard you can do it with boost pressure .
    Any ideas chaps ?
    You can get a boost pressure solenoid that will make it work once the desired boost you set it to is met it if I remember you can control it with a secs monitor but not 100% sure,
        Anyone else ??
          Depends on you act but unless it's high leave the wi in the box it came in.
            Secs monitor could do it
              Would you not suggest it then mark ?
                  Get a spec-r cooler and you wont need wi on it
                    Also iecs monitor will do it.
                    Www.iecs.ch
                    Sent from my GT-S5360 using Tapatalk 2
                    R and B Motorsport www.randbmotorsport.co.uk/shop
                    My engine build & bodywork restoration http://www.escortrscosworth.com/foru...ad.php?t=10500
