Help.. Steering shake!
  • Help.. Steering shake!
    Hi guys... Would a sticking brake piston do this?? It's not all the time but when it happens its undriverble!! It's strange as its there shaking like fook then goes for a while then back again!! Or any other ideas would be helpfull. Think I've heard a slight rubbing on the drivers side wheel..
    Cheers Rich
    MSD Stage 3
    member 42996
    I had this. I changed the wheel spigot rings and thought it sorted it. But it didn't. Turned out that the front diff had come loose.
    Check that the 3 bolts are done up tight.
      Cheers for your reply... What 3 bolts?? My front diff has strangely started to leak recently..
      Cheers Rich
      MSD Stage 3
      member 42996
        I have put the picture below. On it you can see the 3 bolts that the diff to the sump. These are the bolts that came loose on mine.
          Cheers Paul.. That's one area il have a good look at this week! Hopefully sort this problem out before comb!! 😁
          Cheers Rich
          MSD Stage 3
          member 42996
            Well I've been under car tonight spent a good couple of hours checking bolts/ trackrod ends etc etc... & all is tight as it should be!! Checked the AP brakes & all seems to be
            Ok with the discs running freely.. One thing I've noticed is when you turn the steering wheel now & again it judders.. & last time I took it out I noticed the power steering fluid was ... Had been spitting out the tank & was very hot!!
            Is the pump/rack on it was out?? & would this be my streeing shaking problem?? Any help would be great ..
            Thanks Rich.. ��
            MSD Stage 3
            member 42996
              Sounds like it could be your rack but also check your tyres I've had loads of people change bearings etc. and turns put to be a tyre separating or sometimes they go hard or flat spot if the cars standing for a long time.
                Tyres are new & shaking goes one minute & back again.. Say I'm doing a constant speed of 70mph the steering wheel will shake like fook for a bit then go & the cars as smooth as hell Then back again It's a strange one..
                Cheers Rich..
                MSD Stage 3
                member 42996
                  How would a rack cause a shake going straight? I can understand a slight judder when stationary and under pressure, that could be a belt, tensioner, pump if noisy etc. Does or has the car been stored for a long period, have you any other wheels you could try?, you need to eliminate them, perhaps swap them around, get them balanced again, always at the same speed?.
                    could be a sticky dried out cv joint .
                      Had similar problem years ago, bad shaking now and again!
                      The problem went away after changing, what I think is called the a-pan? suspension part, it was badly worn.
                      R and B Motorsport www.randbmotorsport.co.uk/shop
                      My engine build & bodywork restoration http://www.escortrscosworth.com/foru...ad.php?t=10500
                        check bushings...
                          Cheers for your replies guys... Wheels are all straight with new tyres & balancing.. Everything underneath is tight with no play.. Suspension is koni & hads only done bout 5k normal road miles.. It's all poly bushed underneath too.. Car doesn't get used much at all,only for a few shows....I'm thinking its the ap brakes as did get a bit of shaking since owned for 5 years but used to clear when car was used.. But it's not clearing now just comes & goes when using it.. Maybe got a sticking piston???
                          Cheers Rich
                          MSD Stage 3
                          member 42996
                            A-pan is that on the top of the strut???
                            Cheers Rich
                            MSD Stage 3
                            member 42996
