Siemens 55s
  • Siemens 55s
    What's the maximum power these will run?
    Dave
    400 ish
      440 roughly with a little safety there
          ...so I'd just about get away with these on a RB T38 / ported head / BD16 inlet? Which would be good as I've already got a set.
          ps - Jimbo - you guys will be mapping it
            Will they be mapping it on the dyno
              Haven't thought about that yet....!!
                Hi dave, sounds good spec to me fella, will be smooth and powerful with that spec.
                They will do the job as they will be about flat out at the same time your turbo is (generally t38s fall to 26/7 psi by 7000rpm) so should be fine.
                If you were looking to buy some I'd probably say go with the next size up as to kee some safety in the map and future proofing
                Ps we can map on the road or dyno, generally we do dyno then in car check t get the perfect map
                  Thanks Jimbo. Would the 83s that AJC is selling be a better bet then - I could then sell on the 55s I've got, as well as the light blues and greens thatI've also got lol!
                  Dave
                    Yes 83s would be better, it would have good safety then
