Rota Grid Drifts
  • Rota Grid Drifts
    Does anyone else fancy a set of the below especially made for the Escos?
    We need 5 sets to make it happen?
    if interested see Mike Rainbirds post in new items.
    How wide is that wheel in the pic, it looks very dished so maybe 9.5". I don't think 8.5" will look as dished.
      Im not sure, i will ask
        Reason I said that mate, I had some rota gtr on my evo and the looked great being 9.5" as they were so dished but the 8.5" versions didnt look good at all, the face of the alloy was very flat looking.
          Ok good question, i have asked for pics of the actual wheel it would be
            That's 9.5.
            If I order grids they'll be 8.5 and not as dished
            I have just done a stock order for the Forces in 9" wide as they do still have a concave
            Chris
            phone > 07969 182540
              These style wheels have gotta have a good dish to look good, but my rotas in 9" form look great IMO.
                Originally posted by cossymad View Post
                That's 9.5.
                Chris
                Chris,
                It would be very disappointing if they didnt have the concave look, do you know of anything to fit the Escos with a concave look that does not have multi spokes?
                Mike
                  Originally posted by mikedaf2 View Post
                  Chris,
                  Mike
                  Most are fairly flat to be honest, unless you want to go 5 stud conversion. The problem is is that the concaveness is determined by the width and 8.5 just won't cut it. You need 9 or above so if you can get a few others to go for the 9.5" Grid or GTR then you'll be out of luck.
                  The problem is due to strength and desing of wheel and brake clearance. An 8.5" wheel will only be able to have a maximum concaved centre of about 25mm and the centre needs to be flat around 130mm in the centre so has a step of about 25mm too.
                  A 9.5" wheels can imediately have an extra inch meaning a bigger concave.
                    Ooo 9.5" GTR's.
                    I need more money!!!
                      I guess the question is then, would 9.5" wide fit the Escort Cosworth without mods
                        Doubt it. But the mods would be worth it I'm sure!
                          Just about to do a set of 9.5x19" on one so Ill let you know.
                            Will fit the rear, but you'll struggle on the front IMO. 9s with 255/35 tyres only "just" fit on the front.
                              8.5 x 18's
                              Perfect for track and tracklook, but no concave.
