Hi,
I went to start my EsCos tonight. As usual de-armed the alarm & immobiliser and fuel pump started to run. Cranked over and over and over but it doesn't fire? I've definitely got fuel pressure as it is showing the normal level on the gauge. I've taken out the plugs and given them a clean, but it still doesn't fire.
I haven't touched anything on the car since the last time it was out and running. Any ideas what the problem could be?
It's also worth mentioning that when I switched the ignition on for another time without even cranking the car over, it made what can only be described as the biggest bang I have ever heard - similar to a shotgun going off .
Any idea what caused that too?
Cheers,
Agar
. Any idea what caused that too?
Cheers,
Agar
