Ben get some of the padding they use on the floors of Horse trucks. The stuff is about 1.5inch thick and weighs nothing.
I am luck as i have an old 6 ton jack of my dads that goes low enough to fit straight under a cossie diff. I only have to use the above method when jacking up the front.
drive one wheel onto some decent sized wood and then use a normal trolly jack cocker
that is a fookin good idea!!!!, ... ive not used my trolly jack yet & i was wondering how to get it under if it dont fit!.. ive now just got to see where the best place is to jack it up & i can start my winter clean!
I used these for the 911 and also for the ESCOS.
Camper van leveling ramps . Small compact and made of HD PLastic. Drive the car one wheel or 2 onto the ramps and use an normal jack. http://www.leisureshopdirect.com/car...tem_jumbo.aspx
Don't want blocks or ramps got enough shit to cart about
One of them long low slung ones might do the trick on the other thread I'm going over to the car tomorow so will have a measure up... Cheers
So your going to cart a Jack arround in the back of the car instead
I thought this was so you could jack the car up at home.
The plastic ramps are designed to be carted arround in a camper so as to level up the camper on a hilly field
Well I'm going to have to carry a jack weather it's the one I have or a low slung one so may as well get a low one also my cars kept in a container so having to get in and roll it back and forth on chicks would be a headache I'm looking for an easy solution not more work frank
