Who has fitted these? I'm fitting them to mine and would just like to see how you went around fitting the caliper and using the standard caliper as a handbrake
too much rear brake to start with. if your 100% set on it though speak with martin, he made brackets for dunc claire on n55 cos to use standard calipers and 4 pot 330s
I was going to buy some discs and Bells off martin then fab my own brackets. I've already got alcon 4 pots at home to match the 6 pots up front.
I remember n55 having them now, will have a look for some pics. Surely it shouldnt be to much with 380mm on the front and still being 4x4?
Way ott. We had 378 ford Motorsport 6pots with carbon pads up front and full front bias the rear still had too much braking 315 is the tops I'd personally go
Do it if you want too, i wouldnt be talked out of it, just look at how many other people have done it with no issues, also fills the wheels up nicely, if i wasnt saving for the arrival of my first child id be doing this to mine.
