Can you still buy these from ford? thanks andrew
ABS sensors?
Originally posted by Sunnysidebb View PostI found this , but look at te price
[ame="http://www.amazon.co.uk/Escort-Cosworth-Petrol-1992-1996-Sensors/dp/B005I3HENU/ref=sr_1_13?ie=UTF8&qid=1354444003&sr=8-13"]Ford Escort 2.0i Cosworth Turbo Petrol (1992-1996) ABS Sensors FRONT: Amazon.co.uk: Car & Motorbike[/ame] I give up , the link wont work however there £123.89 each
The best thing to do if you're handy with a soldering iron is to cut the connections off the damaged Escos ones and put them onto Saph ones (after you cut the Saph ends off, obviously)
I've already got a Saph set and if mine ever go faulty, that's what I'll be doing. The only difference between the Escos and Saph is the connection type.
Scouse.
Originally posted by Scouse View PostThe best thing to do if you're handy with a soldering iron is to cut the connections off the damaged Escos ones and put them onto Saph ones (after you cut the Saph ends off, obviously)
Scouse.
Scouse.
