FAO Radman / Nick
  • FAO Radman / Nick
    Nick,
    I seem to remember you saying that you retained the Aircon on your old Monte, buy buying a full kit with the Rad, IC and the Aircon rad together.......
    I hope I remember you saying that anyway, as I would like to keep my Aircon, but make it all pretty
    If I am correct, (and I am probably not!) where did you get it from and how much was it if you dont mind me asking?
    Fankoo
    I belive it is Rad-tec, and the whole lot is about £650 ....
      yep as above,its prob gone up since then as well but you do get everything reqd,its a very tight squeeze but at least you keep the aircon and can sell off your old bits to help with costs
        here you go have a word with dan,think hes on here?
        http://www.rapidford.co.uk/index.php?p0=detail&id=245
          Thanks Nick.
          Aaah, that is the one. So I keep the current Aircon set up then? This system just makes it possible to fit it back in front.....
          Did you have your Aircon rad reconditioned, or how did you make it minty? Even though mine is ok, it would be a shame to put it back in looking 2nd hand.
          Cheers again.
            yep thats it, i had to shave a bit off the back of the front cross member, only about 2mm ,and shave a bit off the rear of the plastic fan shroud where it sits infront of the pump,i just sprayed the rad with some mat black to tidy it up and straighten out the worse fins
