Morning all,
New to this site but had my escort cosworth small turbo for 3 years now, have a problem with it at the moment, took the car out for a run about 3 months ago everything fine put it back in the garage and forgot to plug in my charger to keep the battery topped up. About a month later went to take her out again and found that there was no life in the battery charged it up back up to just under 13volts, and the car would crank over but would not start(fuel pump would prime but no engine fire) now the car will not prime and not turn over. The car has a Clifford concept 600 on it which seams to be working fine and it recognises me via the valet code i put in to it, doors lock and open and boot via alarm fob, as the car has been delocked no keys are used to open it, taken the door cards off and worked the locks manually and still no joy. The light on the dashboard by the clock stays on for about 1 min then goes off but still no fire from the engine
. Any ideas chaps
Kind regards,
James
. Any ideas chapsKind regards,
James
get another car and try to jump it
If you had door locks I could tell you how to reset the alarm and immobiliser, but not having them, i suppose you'd have to do it from inside the door panel somehow
