Loom
  • Loom
    I need an engine loom so I've inquired about having a loom made by cw looms they ask if I wanted a knock sensor and lambda put on the loom and I'm not really sure I'm using an L8 ecu do I need these put in to the loom ? They also said that they would need to borrow an Escos loom as They have nothing to size it off as they sizing table got damage in a break in this I don't have I've only got a sierra 4x4 loom with the three plugs on the end can this loom be used in my car?
    It would depend if your chip/program has been written to work with these sensors.
    Do you have a lambda sensor fitted in the top of the downpipe, or in the turbo exhaust housing?
      No mate I have no lambda fitted at the mo but I can if it will make it run better I was thinking of getting a msd chip
        Would it be better just to get these bits put on as I still got to get the car running first and run in before I start choosing the tuner?
          ive got some measurements from a ryan loom i measured up if he needs something to start with
            I would have all sensors put in the loom as it wont hurt if you dont use them and then you have them if needed later
              Thanks mate yeah I ring them and put it to them see what they say
                Its jim cellears escos ryan loom IIRC
                Its not the neatest picture but it is my hand scribblings
                  Looks interesting thanks
                    http://i6.photobucket.com/albums/y20.../IMAGE0001.jpg
                    It's not Ryan's loom it's one of mine that I did for Wenny's MK3 Escort.
                      Get the knock sensor and lambda wiring included - If you don't use them, simply don't plug them in!
                      That's how i ordered my Prometheus loom and i eventually ended up using the extra connections.
                        I stand corrected
                          Call Mark at Bespoke Looms, he can sort this for you
                            I found bespoke looms today on the Internet turns out there about 10 miles away from me
                              Warrens drawings are for a Ryan's loom as I had a spare in the boot of the car
                              OH FUCK WHAT WAS THAT NOISE
