help on building a 3dr from a 1.6 shell?
  • help on building a 3dr from a 1.6 shell?
    has anyone on here done this ive got a 3dr 1.6 shell on a b plate.was wondering what the diffrence in the cosworth shell and 1.6 shells are and can you fit saphire rear beam diff and arms etc ?
    Lee,
    do a search on pf as Paul on there has put up everything that is different between the 2 shells.
    all the running gear will fit.
      cool cheers ive had a look on but couldnt see anything il have another scout about
        All the running gear will fit
        the bulkhead is the only real issue as the hole for the fuse box is different , also the hole where the ABS pump fits
          are the tunnels the same and rear windows ?
            yes they are Lee.
              i read somewere that the earlier ones were narrower wasnt sure wether that was true cheers mate
                could anyone tell me if a 1.6l A reg would have the larger tunnel or anyway of telling
