Adjustable top suspension mounts. One for mr Rainbird maybe?
  • Adjustable top suspension mounts. One for mr Rainbird maybe?
    Had enough of the eccentric top mounts I have. Can any body recommend a decent top mount? Pics of what you have.
    Mike Rainbird do you sell anything?
    Kleers.com 15% discount code 'RON15' for a discount on all cleaning products
    These are mine Ronnie, but dont think Mike does these anymore
    He does do a better set though now
    http://<span style="font-size:20px">...g.co.uk</span>
      the car was in a sorry way there
        comp brake do a nice copy of the 909 top mounts same as i have in the pic. Not adustable but a rose jointed and helps the angle of the coilovers with the adjustable compstruts, tca's and bladed bar etc.
        Not expensive either
          Ronnie, do what Wenny and Warren have done (copy my idea ) and get the HKS ones for the Evo - adjustable for caster and camber and can be made to fit the Cossies .
            Who's that shady looking couple in the back ground.??
            I have compbrake eccentric ones mate but they are a nightmare if ever they need adjusting. Want something that is easy to adjust
            Ok I will steal their idea
            Any links where to get them from please? Thanks
              Wozza has the contacts for those .
                Thanks mate. Just txt him.
                  Comp(romised) brakes
                  Low Slung Denim.
                    what about choosing the camber and castor you really want and have fixed top mounts made to suit the chosen points.
                    Probably the best width for the top mounts is 105cm apart.
                    Next is to choose the castor, say 3deg 30min or at most 4 deg. With fixed points you remove all the complexity of adjustment and some weight too.
                    just a thought.
                    www.Bergsport.co.uk
                      Busted
                      Work Hard, Play Harder
                        just a thought.
                        Good idea Kenny, only problem we have is the tyres... caster camber we use changes due to the tyres we have to run.
                        Last year I ran a lot more camber on the R888's this year on the P-Zero is less, who knows what tyres next year
                          If anyone has a link for the hks ones I'd be happy Do they need any mods to fit?
                            are there any that fit without having to cut the tops of the strut towers off? maybe just a few holes in the trut top, incorporating the strut brace?
                              i'm sure your man for this is mark from mk motorsport.
