Do you use a gasket of any sort between 2 pieces of a 2wd exhaust manifold?
  • Do you use a gasket of any sort between 2 pieces of a 2wd exhaust manifold?
    I'm new to the cosworth engine so little things like this I am unsure of,
    I am using a 25mm stainless spacer to fit a gt series turbo, is there a gasket to go between the main part of the manifold and the trouser section normally or does it just seal on the flange face?
    Also does anyone know the thread size for the trouser piece to manifold bolts?
    Marc
    Didn't have one on my 2wd saphh mate
    http://www.decisiondrivinguk.com/
    "Back off man, I'm a Scientist" - Dr. Peter Venkman
      Nope, nothing between mine either.
        Ok thanks guys
          I asked jim the other day and he just no. Just make sure you clean up the two faces with sand paper first.
          Low Slung Denim.
            As per loader clean up the faces good and bolt up!
