hi all just after some advice as im not 100% on the next step
, Basically my car is a large turbo model and im currently running greens,msd chip and standard intercooler.last year the engine was rebuilt using new shells high pressure oil pump,reground crank 0.5mm o/s pistons low comp with valve cut outs all ballanced up,the head is bolted down on group a gasket and new standard head bolts.The head has been ported and polished but still running standard cams.The question i ask is i want around 370-400bhp what should be upgraded to get to this?what fuel pump,injectors etc would you use or run?any advice would be great
![Dunno](https://www.escortrscosworth.com/forum/core/images/smilies/dontknow.gif)
![tops](https://www.escortrscosworth.com/forum/core/images/smilies/Thumbs.gif)
