i was thinking the other day, and thought the yb needs to breath all the way through the intercooler back through the blower right to the airfilter when its driving normally.....
what would happen if you had a t piece boost pipe on the inlet plenum side and ran a airfilter next to the header tank(obvesouly with a heat guard)
here the thing it would need a flap before the air filter which moved so when theres no boost presure its open and soon as positive boost say 2psi blows through it shuts it off...
surely having a filter right next to the inlet would help the engine breath easier and make more power and cause less lag and use less fuel off boost...
what do you think?? the flap could be similar to the mfi unit on the rs turbos made of metal and can move easily either way
