7.5" rear diff in escos?
  • 7.5" rear diff in escos?
    Will a 7.5 inch rear diff from a scorpio bolt straight on or are the driveshafts/prop different lengths or different bolt patterns?
    The diff wont fit in the beam, you can modify the diff to fit or fit a 2wd beam. Prop is the same size flange but the driveshaft flanges and shafts are bigger for the 7.5"/2wd diff.
    Team S.T.A.M.
      You will need a 7.5 Beam hoop and the 2wd driveshafts the hubs and arms are the same
        I'm pretty sure the Scorpio 7.5" diffs have 100mm output flanges, which are direct fitment, not the 108mm's as found on 2wd cos? just trim .5" off the top left mounting point to fit it into a 4x4 beam.
          No real benefit tho dave
