500bhp
  • 500bhp
    is there many of you running 500bhp on std comp
    is that possible
      hahhahaah no mate
      RS500 8 injector T4 515 BHP
      Restored, Built and Setup by M.A.S Tuning
      The Never Ending Story......
      HERE
        I thought the big tuners were moving away from low compression on YB as the "standard" thing for higher power units??
          of course it's possible! there's yb's with comp as high as 9 and above with more power. Mark Shead isn't running anything below 8 these days afaik. Correct me if I'm wrong on the last one though. Low comp is the safest and (maybe) the easiest way though.
            The last wrc cars ran a high compression did'nt they. They done so for a more rapid response out of corners etc,
              Hasn't CossieRich off PF got standard compression (and even bottom end I think) running near 500?
                Think he has 450ish bhp with a GT 30, standard head, standard bottom end but MAD's own spec cams?
                  surely he has valve cutouts for marks cams
                    Yes Rich's is more or less a stock bottom end, other than the piston crowns having the suitable cut-outs to accomodate the cams/valve lift.
                    His turbo is an internally gated GT3071
                      Depends on the management your running , as newer ecu's can be mapped more acuratly to stop det ... erm or summit.
                      Mark shead did tell me this when we went there with Dan's car but , it was a while ago and im a little hung over today. lol
                      Low Slung Denim.
                        thanks lads i have a L8 to run 8 injectors roller t4 hart inlet plenum with 8 greens 16 inlet cam 14 ex cam big ported head
                          It is possible like loader says if the management can keep up with it so to say. Ive dropped mine to 7-8-1 for 500 as per Harveys instructions and thats going with pectel
                            [QUOTE=cosmagedon;196831]It is possible like loader says if the management can keep up with it so to say. Ive dropped mine to 7-8-1 for 500 as per Harveys instructions and thats going with pectel [/QUOTE
                            who,s mapping yours then m8
                              All my current engines are 8-1
