Rwd prop
  • Rwd prop
    I read ages ago that you can keep the standard prop on a rwd conversion and use a automatic granada out put flange, then it all bolts up to the doughnut.
    Can anyone confirm this? i was at ford today and we were trawling through ******** and found a few pics that looked promising but wasnt going to order anything untill it was 100% confirmed.
    I'd be interested to hear the answer to this; I'm gonna be converting my car in the next month or so's time.
      just noticed its blanked *********** out of my first post
        How much was the flange from Ford? Might be worth biting the bullet and giving it a go
          We couldnt find a price mate, but the crade is £18 all in
            What about a finis
              For the flange? Didnt get one will try again tommorow but i just want to confirm that it will work before i buy one
                One piece 3" custom prop is the way to do it on a rwd, cant be that much over there. Paid under £500 to get one made here in Norway.
                  Already spoke to jano about one, £270 was just checking out other options
                    ive just had mine done , i got a 2wd prop ,then i think they put the front peice on my escos prop ,after it was shortened ...cost about 100 to do and 25 for the 2wd prop
                      I have looked into this and it would apear that you need the output flange from a 2 liter auto Granada gearbox. I'm happy to buy one and give it a try, however I don't want to try and get the finis off of the local ford parts muppet
                      can anyone help with a part number?
                        Found it and checked it Third part from the bottom on this page: http://www.southwalesprops.co.uk/pro...ranada_mk3.htm
                        35mm and 25 splines is the same as the 2wd prop
                        All I need now is a Ford part number, anyone got M I C R O C A T
                          Progress keep us updated
                            I have one on the wayfingers crossed
                              Where did you get if from mate and how much?
