378mm ap's
  • 378mm ap's
    has anyone ever had bother with there calipers touching the wheels when using 18"monte wheelsthe outside top and bottom edge of my caliper is touching the wheel
    Thanks Mark.
    NORRISMOTORSPORT 01773836274
    WWW.NI-FORDS.CO.UK
    think a few people have had da same prob and i tink involved machine either da caliper or bell abit.
      I had this problem with only 1 of my calipers touching the inside of my Rondells. I gently filed a slight chamfer on the edge then repainted the caliper.
        how much clearance do you have now?
        Thanks Mark.
        WWW.NI-FORDS.CO.UK
          What callipers - CP7040 or CP5555?
            cp 5555 mike
            Thanks Mark.
            WWW.NI-FORDS.CO.UK
              Just do what Dave suggests, it is not an issue and will literally be a few mm .
                thanks mike
                Thanks Mark.
                WWW.NI-FORDS.CO.UK
                  I don't have those wheels fitted anymore, but I only had to remove 0.3-0.5mm it really wasn't a lot
                    Mark are you changing the wheels on the ecos? pics please
                      yes hugh but need to sort the brakes first
                      Thanks Mark.
                      WWW.NI-FORDS.CO.UK
                        18inch monte's
