carnt select gear
  • carnt select gear
    what caused the gearstick to not select gears and the car is stuck in gear even though you can put the gearstick to neutral
    as i have a 4wd sierra on my drive now and carnt move the thing as i carnt select a gera
    it did sound like a full straigh cut gearbox when comming down the road but when clutch is in it disapperared
    i had it running on my drive i turned it off and when i went to start it it somehow had selected a gear and almost went through my fence
    Third gear will have failed the bits of teeth floating around in the box cause alsorts of issues Such as locking in gear
    upsetting the establishment on PF since 2000 http://thealpinaregister.com/forums/
      but theres no rattling from gearbox or nothing
        Sounds strange
          yeah, it drove from surrey to coventry without any problems, until about 5 mins away when it started to sound like a straigh cut, hence i thought it could be release bearing as it disapperas when you pressthe clutch
          what i dont understand is how it managed to select a gear when i left it in neutral and why i carnt get it into gear
            its prob clutch bearing has broken completly so not allowing clutch to work at all
              carnt be as if i press the clutch in the car doesnt move anywhere
                Id say a problem with a broken gear as blacky suggests.
                Problems in the gearbox somewhere as it goes away with clutch depressed and hence transmission not rotating at all.
                  Whev the box in the van broke it did the same as your describing it tryed to run wenny over
                  ticking over one min lurching farward on it's own the next
                    bugger
                    nee to find a box for a v6 4wd now , and its only for a couple months then its getting a cossie motor in it
                      you sure its not just the selector lever poped of the pin ontop of the box hence the clutch doing its job but not being able to move gears?
                        ill go take a look see if i can get my hand down there from inside the car, but i dont think it is that as the gearstick doesnt have a lot of movement
                          pins definitly still on as it was off i should be able to grab the rod and move it easily but its solid same as the gearstick
                          time to hunt for a new box now
                            oh well was worth checking tho mate
