Anembo Engineering 6 degree beam
  • Anembo Engineering 6 degree beam
    Has anybody fitted one of these? I was think of upgrading, as I’ve heard these are pretty good.
    Any experiences with this company?
    John
    I’ve got an aneembo one on mine it took them 4 months to have it made which was a bit of a wait but quality bit of kit
      Thanks for the reply, and good tip on the lead time. I'm not in a rush for it, as the car is in a million pieces, so might just get one on order now and will hopefully be with me when needed to fit.
        Think its old mk design, heard its not the best out there
          What have you heard? Are you saying the geometry is incorrect? If so, which ones are better, and where can I purchase them from?
            Hard to adjust, and hit the floor, so need to put a spacer on main bush... Kind of think it was on here i have read it.
            Harvey gibbs or groove garage i guess would be safer choices
              Harvey gibbs or groove garage possible?
                Ive got SCS Harvey and Jims 6deg beam. Simple to fit together and looks great
                www.sunnysidebb.co.uk
                  Another
                    Looking at those pictures, am I correct in saying that there is only adjustment on the inner swivel/bush points? The outers seem to be the standard bush? The Anembo one appears to have adjustment on both. Is this really necessary, or what are the advantages/disadvantages?
                      Also have the OMS beams
                        Originally posted by Sunnysidebb View Post
                        Another
                        What size rod ends are those on the SCS?
                        John
                          The adjustment is via adjustable spherical joints in the arms and a slot in the beam . Gives plenty of adjustment for camber and toe. A little tricky with the slots setting it up on your own but non the less quite doable.
                            i have the MK one fitted, not had any issues with fitment or geometry, plus once set up correctly makes the car feel much more planted, i would highly recommend it, i thought the solid bushes would feel really harsh but it feels good, I'm on black art coil overs as well.
                              Literally as Darren just said, Mk beam (which is what it really is) is a fine piece of kit. Shame it can’t be seen as it’s a lovely piece of kit. That and the SCS beams are the most tested out there and completely change your car.
