Fuel Pressure Regulator needed
  • Tech Question - Fuel Pressure Regulator needed
    Hi, I am in the process of tuning the BT with G4 fury. I got some fueling problem. Sometimes it hit the target sometimes is running bloody lean. The fuel pump and injectors are new. I am suspecting the regulator is the problem. I haven't take it out yet. Searching online, GGR got a regulator for silver top, does it work for BT? Doing more search, it seems like BT regulator isn't available anymore. Is that true?
    I would think both small turbo and big turbo Fuel regulator was the same.
    some options.
    https://www.ebay.co.uk/itm/122211883...EAAOSwal5YHF~4
    https://www.ebay.co.uk/itm/160500397...Cclp%3A2334524
      Hi i have a new one i bought but never used think it a bosch one
        Anyone tried any of those FPRs linked above on a BT?
        I am trying to get one for my BT too, but can not find any with that type of housing for the BT. At least all descriptions says it is for ST only..
          Didn't bt and st both get a 3.5bar mini reg?
          John
            St and bt share the same size of fitment?
            i went to look at the regulator, it has 0280160661 printed on it, and XXBar which is faded and cannot read. I don't know if the prevoius owner change it correctly or not.
              Thanks alot. I am not in the UK. I hope I can get it locally. Thanks for the ofter.
                Hi can post any where
                  Try this
                  https://shop-autodynamix.co.uk/p/esc...fuel-regulator
                  RSOC Member 16886
                  Darren Parker
                  07539-936944
                    finally i brought a e36, 3.5bar and exact fit to the original fuel rail. running good now. running correct fuel pressure, the lambda guage is reacting when i tune it with G4.
                      Good news. No Cosworth tax to pay I suspect either.
                      www.sunnysidebb.co.uk
                        do you have a link for the e36, 3.5bar Reg ?
                          Pierburg 7.21548.51.0
                          spent US$51.5 brought it locally.
                          I didnt think it is any cheaper than in UK, but certainly cut the shipping. Hope anyone outside of UK can benefit from this.
