Side Skirt inserts
  • Side Skirt inserts
    Took my side Skirts off today to inspect sills. I bought the clips off the forum a while back in readiness. However, I found they were held on using double sided panel tape and all the little round inserts that the clips pop into were missing.
    Any ideas where they can be obtained from?
    www.sunnysidebb.co.uk
    if your not in a big rush i can get some 3d printed for you for free if you can wait a week or so, if my memory service me correct you need 14 ? i do have some spare clips that go on the side skirt if required as well
      They are still available from Ford. Finis 1667246. Also on ebay, cheaper than Ford too
        That’s really helpful
          Fantastic. Off to ebay right now. EDIT: Pack 16 now on order.
          Thank you.
          What about the rivets at both ends?
            Thanks Jim
            Great offer, thank you however. Ive just bought 16 off ebay with the finis code given below.
              Originally posted by Sunnysidebb View Post
              Thanks Jim
              great you got sorted
                Thank you.
                Finis 6158749, again available from Ford and ebay. The most expensive rivit in the world because they have a plastic sleeve.
                  That plastic sleeve is there to prevent some even more expensive corrosion!
                  when I worked at a Ford bodyshop we called the condom rivets !
                    Thanks. Used that number on ebay. £5.99 each.
                    Will keep looking.
