Anyone know max "bend" in crank on cosworth?
Tolerance crankshaft?
Everything expand when hot, and things happen under load. I just trying to find out what is "safe" acording to Ford on the yb? I have now put that crank in a block, and turns fine now, and with the clearance i managed to get from take of abit on the bakside of bearings, i hope its fine.Originally posted by scoffstainland View Postbolt it into a block and check it spins 360 degrees with no tight spots
