the type martin does, the pro and cons and what tunnel mods are needed as the cars about to go to the bodyshop so if i go this route i want to get the tunnel done now
look at my resto im having the gearbox and already done the mods
but depends on what gearbox your using, i kinda went about mine the wrong way but its done now and strong
pros, std gearboxes can take 500bhp all day, plus rwd and 4wd ona switch, and the car will launch like a skyline, cheap to replace
cons, big and heavy and have to have tunnel mods, custom gearbox mounts, adaptor plates, plus spacer plates for flywheels, and different clutches, and front and rear props
Wenny with your car being so light, think I would have stuck with the Bara unless it broke.
Dave had 600bhp in Yum with full trim, and his was alright apart from the uprated shaft.
Defo would have give it a go..
if you do go with it, id look for a skyline gtr thats scrap and get the gearbox tunnel out of it and out that in, after i did mine my mate scrapped his gtr shell which really annoyed me as icould of done a much better job
I take it you want to go for the fully sequential box? Martin does a bellhousing that bolts straight on in that case best bet is to give him a bell
ye thats the on mate, ive looked on his site, ill give him a bell, just wonderd if any1 had done it, i wonder if marins is a fitted price
i seen richys
i seen richys
Would also be fun to have the 2wd / 4wd split switch, i think its rather good value to be honest but a little bit more weight,but with 680bhp dont think thats an issue! What would the ffd come in weight wise plus all the extra parts needed to run?
im not sure on weight difference but would lkike to know what both kits weigh
