Pro Alloy Rad and slim fan set
  • Pro Alloy Rad and slim fan set
    Just thinking ahead as I'd like to get mine fitted as quick as possible, but does the L shaped water pipe have any fixing points on the PA Rad? As I dont seem to remember seeing any
    No fixing points mate but it's easy enough to sort.
    Bell me if you like
      Have drill? Have mounting points . Just a case of drilling the lip on the bottom, if memory serves me correct, it is then bolted on with a couple of M6 bolts I used nylock nuts for all these .
        As above
          Arse, so this is something that I need to do with the pipe off the car then......
          I've had the slim fan brackets powder coated black, and was fitting it all up tonight. Kinda hoped that I'd be able to just whip off the pipe and would be able to mount on existing holes.
          Mike - M6 ARE YOU SURE!
            You could probably do it all on the car if the radiator lip is lower than the intercooler, but would need the bumper removing, as you would need to do it from the front .
            They could be M8, but thinking about it, I'm pretty sure they are M6 .
              Thanks gents!
                Definately M6. Only a couple of holes to drill. Very easy with a nice sharp drill. See below
                  wheres the top bracket fix to?
                    I didn't put anything in the top mount. Didn't need it with the bottom ones done up and the hose on the top.
                      where.d you get the water tube from Paul?
                        Just sold my one, GGR do them about £45
                          ahh ballbags!
                          Might just reuse mine
                            Got mine off Ebay. Can't remember how much it was.
                            Just looked here is the GGR one which is £60 including postage
                            http://cgi.ebay.co.uk/GGR1255-Escort...item5ad41542f5
                            I think Auto Specialist do them as well.
                              sod that then, old one can go back on lol
