I've bought a new heatshield, what mounts do I need for them and are they the same as 2wd? Where's the best place to find them? I've seen lots of different types....
Heatshield mounts?
Heatshield mounts?
My Series 1 4x4 cosworth build
My 2wd WRC escos track car build
I get all my bits from www.mattlewismotorsport.co.uk/Tags: None
There are two mate, a kind of lower bracket that holds the bottom of the shield that bolts to to the drivers chassis leg (or there abouts) and then there is another that bolts through from the inner wing half way up, its a 100mm hex type affair, a bit like the posts that are used on the early YB rocker covers to hold the cambelt cover on. I have pictures, but not on my work computer. I'm sure someone will have some to hand.
As for getting the brackets, a few on here were making them - might have been Dave or Mark Barber?
Is the bottom bracket this one?
https://www.ebay.co.uk/itm/192159251287
and this is the hex type one that goes on the inner wing?
https://www.ebay.co.uk/itm/332183987741
Both those links are wrong mate, top one is escos engine mount heatshield bracket and bottom one is 2wd bottom heatshield bracket
You should know by now who to call, and it aint Ghostbusters
- 1 like
Just purchased some from Dave, thanks for that. I know where the side mount goes but does anyone have a pic of where the rear mount fixes onto the bulkhead?My Series 1 4x4 cosworth build
try againAttached Files
Ah perfect, I thought it was on the bulkhead.My Series 1 4x4 cosworth build
