help, morrette inner, light diameter, or the holes internal diameter
  • help, morrette inner, light diameter, or the holes internal diameter
    as above please asap please my munchkins
    Jim i will nip into the paint shop tommorow and check for you
      ok buddy, im hoping i have a spare light at work, if not i will wait for your kind self
        No probs Jim it will be around 2-3 oclock and i will report back then bud
          thanks pal
            ACUTAL light is 13cm the part you can see IE the hole dia is 12cm,,,
            AND i know i'm the king
              Jim i p.m'd you all those pics with sizes didnt I ?
              Low Slung Denim.
                no sizes bud, got the pics !
                  oh yes you did its in the pics LOL
                  just over 100mm, dont think 4" is gonna be big enough
                    its nearer 11cm jim those pics arent took with the ruler centre! i have a light in a box here i measured last night!
                      Jimbo i see you have the sizes so i take it you have what you need
                        126mm lamp diameter
                        112mm hole internal diameter (morette lamp exterior casing, which is visible outside the car)
                        80mm hole diameter (morette lamp mounting plate, which is visible from engine bay)
                          Originally posted by suzuki123 View Post
                          126mm lamp diameter
                          thats the ticket !
                          thanks everybody bunch of starts
                            why not get Bullett to send you some of the ones we have used
