engine removal
  • engine removal
    Hi on a escos can i take the engine out the top if i remove the head first thanks
    bit awkward but they do come upwards yes
      why remove head first?
      www.sapphirerscosworth.com
        Remove gearbox and clutch and flywheel and all will come out the top
          It will come out top but is so much easier to go out the bottom it don't damage anything going out the bottom
            Engine,gearbox, subframe all out in one, lower onto a low trolley, lift car up and wheel engine out.
              an hours work maximum
                thanks
                thanks
                  Definitely the easiest way.
                  Not sure about it taking an hour like
                    I was going to ask him to come show me how it takes a hour
                    Id say 2 1/2 tops
                      2wd
                      Mine not to bad as its 2wd
                        2wd will go out top of problem
                          I mean out bottom not top sorry
                            In that case then 20 minutes to get a 2wd out
                              Id say 2 1/2 tops
                              Pussies, I did it in 40 minutes
